Delete a linked sketch problem
Hi
Is there a way to delete a sketch linked to other sketches without deleting the
The sketches that are linked to it
Thanks in advanced
Thanks in advanced
RE: Delete a linked sketch problem
For example, let's say that sketch1 and sketch2 are both simple rectangles. One of the lines in sketch2 is constrained to be co-linear with a line in sketch1. Edit sketch2 to remove/redefine the constraint that ties it to sketch1 before deleting sketch1.
www.nxjournaling.com
That is my problem
in the graphics window I see
magenta dashed sketch curve ( links between sketches)
but in the sketch show/remove constraint I see something like this
A3 Tangent to L3
without info to wich sketch are belong
if show/remove constraint was like this
A3:sk01 Tangent to L3:sk00
their is no problem to identify the links and remove them
Thank you for your replie
