Appropriate code evaluation
I have been asked to design the connection of a carport structure to top of a deck of a barge
Curious to know what codes need to be utilized?
Does the ASCE applies for the wind load on a carport on top of a river barge?
Is AISC applicale for design of posts/columns to the top of deck?
Apprecaite structural engineers or mechanical engineers that are familiar with this subject to direct me.
Sincerely,
Your Collegue
RE: Appropriate code evaluation
I assume this is related to your wind post in the other topic. Should have just kept them together.
I know of no code that covers your situation but that doesn't mean it doesn't exist.
I'd say using ASCE and AISC are a good way to provide a reasonable measure of safety. This would seem to fall under a "building-like structure" to me.
Maine Professional and Structural Engineer. www.fepc.us
in addition to ASCE & AISC I would also take a look at the motion of the barge and how it affects the wind cases. Then check the wind on the canopy for the typical cases and then check it against a wind case when the barge is rolling and tilting the canopy into/away from the wind @ some angle...45degrees might be an upper limit or any other case that might govern...one can use their engineering judgement as to what is reasonably possible....
Interesting loading question...
Can the barge be towed to anywhere in the world, or will it be restricted to a certain position or locale. Answer makes a whale of a difference on the loads to apply.
Mike McCann, PE, SE (WA)
msquared48 (Structural),
This barge should be stationary most times as kind of being used as a deck by the shoreline of river but it may be moved to different location for the same service.
Could u please explain the two cases of loads that you refere, "Answer makes a whale of a difference on the loads to apply"?
Thank you very much
I am burning to learn and understand this.
I think msquared just means that there is a big difference in the ASCE 7 wind loads if the river is in the Florida panhandle versus Ohio. If it can theoretically be moved locations, you'll want the worst case wind loading. SAIL makes a good point about the motion of the barge affecting the structure. You may want to consider applying some displacements at the top of the structure to capture the effect. How much displacement is probably based on engineering judgement.
You might try looking at the structural requirements of the IACS rules for bulk tankers. They would be slow movers, like your barge, and they often have odd and ancillary structures above decks. There might be some helpful guidance there.
Thaidavid
Potentially also look at harmonic oscillation loads on the connections as well. Wouldn't want to turn this into another Tacoma Narrows bridge and a boat has an almost limitless number of frequencies it can throw at a stuff attached to it.
I would call the closest Coast Guard unit.
There may be reg.s that engineers don't normally deal with. If the river has locks, you should be able to find them.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
depending on the size of the barge and the size of the canopy, another area to check would be the affect of the canopy on behaviour of the barge ie. stability, hydro performance, etc...
