How to play a NXJournal (.dll) or a Macro inside a NX open code?
Hi everybody! I've been looking for the way to execute several NXJournal dll or several Macros in a certain order and I found two examples about it but neither of them work in the proper way.
For example:
In the case of NXJournal
I found this example:
'' This example demonstrates launching another VB .NET application's Main entrypoint.
'' The Launching application might look like this:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main()
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = s.ListingWindow
lw.Open()
Dim libname As String = "launch_it.dll"
Dim fullpath As String = Nothing
ufs.UF.FindFile("application", libname, fullpath)
If fullpath Is Nothing Then
lw.WriteLine("application\" & libname & " not found")
Else
Dim nada() As Object = {} ' Main doesn't take any arguments
lw.WriteLine("Launcher will now attempt to Execute " & fullpath)
s.Execute(fullpath, "NXJournal", "Main", nada)
End If
End Sub
Function GetUnloadOption(ByVal arg As String) As Integer
Return CType(Session.LibraryUnloadOption.Immediately, Integer)
End Function
End Module
You can find that here : http://www.eng-tips.com/viewthread.cfm?qid=327153
but since this line: "ufs.UF.FindFile("application", libname, fullpath)" It has an error an the program stops working
the error message that is shown is: "Fatal error detected unable to continue, unhandled operating system exception: e0434352"
then I have the second solution with the macros
I found this:
Module NXJournal
Declare Sub MACRO_playback_from_usertool Lib "libugui" Alias "?MACRO_playback_from_usertool@@YAXPEBD@Z" (ByVal lpName As String)
Sub Main
MACRO_playback_from_usertool("C:\temp\test.macro")
End Sub
End Module
Sub Main
End Sub
End Module
and it works well when I use just one macro but if I want to execute several macros like this:
Dim macro As New List(Of String)()
macro.Add("D:\Users\212464629\Desktop\run\base")
macro.Add("D:\Users\212464629\Desktop\run\componente1")
macro.Add("D:\Users\212464629\Desktop\run\componente2")
Try
For Each path As String In macro
MACRO_playback_from_usertool(path)
Next
Catch ex As Exception
MsgBox(ex.Message)
End Try
Try
Next
MsgBox(ex.Message)
End Try
so then it just play the last Macro in the array.
So I've been searching for more information about this problem but I haven't found it yet.
If you know something more about it I will be really grateful for your help.
RE: How to play a NXJournal (.dll) or a Macro inside a NX open code?
I found another way to solve my issue so I´m going to tell you how I solve this, in case of someone else may have the same problem.
Even Though already I have one solution, I would be very happy of receive others tips, information, recommendations and so on.
In my case I wanted to play several macros in a specific order, so I decided to concatenate each macro in another unique macro which contains the sorted macros
macro.Add(My.Computer.FileSystem.ReadAllText("D:\Users\212464629\Desktop\run\macro.macro"))
macro.Add(My.Computer.FileSystem.ReadAllText("D:\Users\212464629\Desktop\run\macro2.macro"))
Dim text As String = Nothing
Dim i As Integer = 0
Try
If i = 0 Then 'the first macro has to be with all his header
text = path
MsgBox(path) ' this comment is just to check the content of the string
Else 'the consecutive ones has to be without their headers and in my case I decided to start concatenating since the first command which all the macros have in common, in my case "RESET"
Dim index As Integer = path.IndexOf("RESET")
text = text + path.Substring(index)
MsgBox(path.Substring(index)) ' this comment is just to check the content of the string
End If
i += 1
Next
MsgBox(ex.Message)
End Try
Dim _path As String = "D:\Users\212464629\Desktop\macro.macro"
Dim _file As FileStream = File.Create(_path)
Dim info As Byte() = New UTF8Encoding(True).GetBytes(text)
_file.Write(info, 0, info.Length)
_file.Close()
MACRO_playback_from_usertool(_path)
