Revolved Section
Revolved Section
Revolved Section
Hi NX'ers
In the 7zip folder is a drawing of a simple assembly. Open the drawing and there is a revolved section, what I want to know is, is it possible to some way add another leg to the section to include the outlet as indicated by the annotation so it appears in the section view and displays the same as the other 2?
Many thanks in advance
Si :)
NX8.5
Best regards
Simon
NX7.5 NX8.5 NX9 NX10
NX Consultant
www.team-eng.com
RE: Revolved Section
Not if you want to see all the outlets breaking through completely and uninterrupted. I would cut a section through the ORTHO@25 view for the full length to show the larger outlet and full length section. Then you can move your legs in ORTHO@19 to cut through the smaller outlets. Either way, you will need 2 section views. My way just uses 2 different parent views.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
