Switching between sheets
Guys,
Any idea about the hotkey or shortcut for switching between sheets instead of clicking on tabs atom
Warm regards,
Akhtar Aziz
RE: Switching between sheets
what's the difference between to click on tab or to click on shortcut?
Sorry if i have confused you.
I am talking about hotkeys like Ctrl+tab for switching between windows in CATIA or Ctrl+S for saving a document. Is there any hotkey for this as well ?
Warm regards,
Akhtar Aziz
Try the Left and Right arrows to jump between drawing sheets.
Playing around with this, I discovered that Shift + arrow and Ctrl + arrow work also! But, if you press the Up or Down arrows, you turn off the Left & Right jumping (reset by selecting a tab).
I tried it and found that it only works if you have already selected or clicked on the sheet tab. Otherwise it is deselected. So goes the same as clicking on the sheet using a mouse.
Warm regards,
Akhtar Aziz
I will do that. Seems not a bad option. Thank you.
Warm regards,
Akhtar Aziz
