G76 in NX 8.5?
G76 in NX 8.5?
Hi, everyone
I have some questions about G76 fine boring operation, I don't know where to find it. And what is the difference between single hole and single bore?
For now, I have tested several operations and output the NC code. Some are obvious when I tried to match the operation with the description in the G code list. Some are hard. So I wonder if there is a list that matches the operation to a specific G code?
It seems that the "boring" and "reaming" operations are all corresponding to the G85?
RE: G76 in NX 8.5?
Each cycle type can be customized in the post for a specific machine tool.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX7.5, NX9.0, NX10.0(Testing)
Vericut7.3.3
RE: G76 in NX 8.5?
In cycle list. "Standard Bore, Drag" -- G86; "Standard Bore, No Drag" -- G76
