Vertcut G code??
Vertcut G code??
Vertcut G code??
can anyone help me with the G code for the Vertcut progrogm something got erased in my program, We have an Amada FO-3015 laser with a fanuc 160i-L control THank you!
RE: Vertcut G code??
I've worked with the 3015 for 20 years but I'm not sure what program this is can you explain it more. Thanks
its program O015 in our control,,,, its where you set your y and z distance to make a straight cut
If you ever need to make a shear program all you need to do is program a square and post it and edit the post.
