Problem solved - Optimization parameterfile does not exist.
thread799-372015: Abaqus optimization error due to missing parameterfile
I got the same error message:
Error in Opt-Process-1: Optimization parameterfile given by --opt <parameter-file> does not exist.
Error in Opt-Process-1: Check that parameterfile "Opt-Process-1.par" exist !
Error in Opt-Process-1: Optimization process failed with an error.
I simply solved the problem by setting up a working directory and saving the x.cae file.
