GE 800 Series Relays (850, 845...etc)
Hello All,
We have recently been purchasing the 800 series feeder protection relays (850) and transformer differential relays (845) per our customer specifications on some substation jobs. These relays have to be ordered with different firmware packages based on the relaying options that is required. For example, synchronism check is not part of the base relay and has to be ordered with the sync check (25) option. When up loading the new firmware, it doesn't seem to "stick" and needs to be rebooted several times.
We have also had problems with the pushbutton functionality intermittently working. This also required a reboot of the relay. Since the Pushbutton function is written to logic, and the logic essentially stopped working and the relay had to be rebooted...........does this mean the actual protective functions would have also not worked?
Has anybody had any experience with these relays? If so, have you had similar issues?
RE: GE 800 Series Relays (850, 845...etc)
