Connecting neutral to ground in a ALC switch?
An Onq ALC dimmer switch requires uninterrupted 120 VAC that must be present at each switch loaction. In addition, they also require AC neutral. I do not have a neutral at the switch location but i do have a ground. Could anyone help on this problem.
RE: Connecting neutral to ground in a ALC switch?
Most North American codes, and probably others require an insulated neutral.  "Noise" may be a problem substituting an equipment ground conductor for the purpose.
hi...
you have to use an isolation transformer ...1:1 ratio will do the job..and you are troublefree..
dydt
I agree with busbar that a connection to ground is probably against code.  It would probably work, electrically, but I would recommend against it.  Codes are there for a reason.
I disagree with dydt, I don't see how a transformer could possibly solve your problem.  In addtion, any possible configuration you came up with for a transformer connection would require a connection to ground, which would be against code.
My recommendation is, run the neutral.
