Making components transluscent in an assembly
I have an assembly that I want to show some components in a translucent/transparent manner so that you can see into the belly of the component while still seeing the outer shape.
I found a like that refers to 'styles' menu or by going View->Style and assigning some colour to a component, but I do not find this in NX9.
I suspect that I can do this by setting component materials, but I really just need this for display and if I have to assign a material to each component I think it will affect the model performance negatively on my PC and 'grow' the file unnecessarily.
I can also assign colours to features when the part is made the 'Display Part' by going Edit->Feature->Assign Feature Color, but it does not seems like they can be made translucent. I also really just need this in an assembly and don't want to have to make changes to the parts themselves.
Thanks in advance for any advice.
Here's looking at you, looking at me, looking at you
RE: Making components transluscent in an assembly
I figured this out and can perhaps answer my own question for if someone struggles with this in the future.
If you highlight an object and hit ctrl->J or right click on it and go 'Edit Display' you can assign a colour to the object along with a translucency from 0-100.
It seems like these attributes are part of the component as a part and in an assembly, but it is such a basic attribute that I am sure it won't really do anything to performance.
