Altitude Correction Factor
3
Dear friend´s
please, anyone know how was determnate this formula. any literature about this?. Why is a exponencial..? and how determinate the value 8150... etc
Ka = exp(m*(H/8150)
:D
thx
RE: Altitude Correction Factor
THX RBlais13
but i need information about the formula, how was determinated..? any paper, literature can help
thx
3
miltonboss,
This altitude correction factor is based on the change in pressure with height.
The correction factor that is applied is proportional to the ratio of the air pressure at sea level over the air pressure at elevated height (ie p0/p, as you are multiplying by Ka)
It can roughly be calculated by p = p0 exp-(g.M.H/R/T0)
where
g = gravity = 9.8
M = molar mass of dry air = 0.029
H = height above sea level = the height you want the pressure at
R = gas constant = 8.31
T0 = sea level standard temperature = 288 deg K (273 + 25 degrees K)
Now if you group all the terms in the brackets, excluding the height, you get (g.M/R/T0) = (9.8*0.029/8.31/288) = roughly (1/8000).
So now P0/P = exp(m*H/8000) ish. The exponential becomes a positive because you've moved it to the other side of the equation.
The m varies with the type of voltage being applied (ie ac, dc, impulse)
So ultimately, in answer to your original question, is it an exponential due to the rate that atmospheric changes with respect to height, and the 8150 comes from that equation when you insert all the constants that go into it.
ausphil
Dear ausphil
thank you so much for your reply. It really helps me a lot
thanks
miltonboss; Around here we give stars to thank responders. Bottom right.
Keith Cress
Taken care of. winky smile
