Entering and Tightening Clearance - Base Plate
What is the required clearance from and Column face to the bolt center-line for a 3/4" bolt?
Referring to Table 7-16 of AISC 360-05 it appears the socket size is 2-1/4" and the minimum dimension would be 1-1/4". Right?
RE: Entering and Tightening Clearance - Base Plate
Also consider using an open face wrench and using a socket on the bottom if you are having clearance issues.. If that is applicable for your situation
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
EIT
www.HowToEngineer.com
