CADKEY 99 Serial Key Installation count
I have an old cd here at work of CADKEY 99. Have a few old files that were created with the program. I'd like to know if anyone knows how many computers a CADKEY 99 serial code is good for? is it 1 computer per code? or something like adobe suites where you can install 2 computers per key? Asking because believe it or not we still use CADKEY 99 at work and I'd like to be careful to not install a key we're already using unless I'm able to.
RE: CADKEY 99 Serial Key Installation count
Look in Tools/Options for the screen size input boxes. You can type in your x and y dimensions which should solve the problem. I ran into the same thing when I went from a CRT to a flat screen monitor.
Kyle
