Faster workaround for this API 'feature' ?
I just discovered that the CreateFlatPatternFromModelView
 API call does NOT return an error if it successfully creates a view, with an unsuccessfully flattened part (ie, Model has errors preventing it from unfolding)
If there is only one config in the part, or if the current config on opendoc is the one with errors, I can trap the error in OpenDoc. However, the more configs there are in  the part, the less of a chance this will happen.
Any time I change configs, SW will do a rebuild, but there is nothing in the activateconfig call to return an error, so do I have to rebuild each configuration twice, just to catch any possible errors before generating a flat pattern?
RE: Faster workaround for this API 'feature' ?
This does not sound right, please report it to your reseller. Even if you don't have support they should help you with bugs.
cheers,
Joseph
