How do I read in Catia .exp files
I have recieved a large quantity of catia files with the .exp extension. We run Pro_e but have a seat of catia for conversions. How do I read in the .exp file directly into catia. I get and error "Open failed due to invalid or incosistent extension typ". Any suggestions Please
Kevin
Kevin
RE: How do I read in Catia .exp files
in ENG TIPS go Keyword search... type EXP... Read previous questions and find what you need..
Have fun,
Eric
catiav5@softhome.net
You can extract the ".model" from a export file with the command :
.../.../CNEXT.exe -batch -e ExtractModelFromSequential
On windows, copy the raccourci et complete the command after "cnext.exe"
Bye
Pascal (I am French)
Business Partner CATIA V4 & V5
but beginner in English language
plambert@rgb-technologie.fr
the .exp extension means that the CATIA models and some other stuff were exported. You have to run the CATIMP utility program to import the files into your CATIA system and then you'll be able to read the model files and convert them to Pro-E
....Jack
Is there a way to bring .exp into V5? I do not have acess
to V4.
Kevin
do the search thing and you ll find out..
Have fun,
Eric
whith v5, make a copy of shortcut on your desktop, and after that complete on shortcut properties, on target, whith: "CNEXT.exe -batch -e ExtractModelFromSequential"
When i run the batch ExtractModelFromSequentia i cant see any text or demensions. Can anyone help?
No internal or external prj
No visualization of text and demensions
Please inform V4 project file path in Tools/Options.
