A tool or target body is not a sheet metal body
Hi
Here is a mystery.
We recently migrated from NX8 to NX9 and we are getting warnings in the Boolean unites:
-A tool or target body is not a sheet metal body. Convert to sheet metal may be required to support further sheet metal features.-
We don't use the sheet metal application.
Its only a warning, the operation is completed successfully, apparently it happens when we unite bodies created in NX8 with bodies created in NX9.
Even removing parameters and exporting and importing x_t's it still has a way to determine if the body was created in NX8 or NX9, and whenever we unite bodies from different versions the warning comes up.
Is this the intended functionality or is there a setting we can toggle?
Here is a mystery.
RE: A tool or target body is not a sheet metal body
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am not completely sure the bodies were never converted to sheet metal, I know the -convert to sheet metal- command, is there a reverse command? something like, forget you are a sheet metal?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
