Guidance for bearing on wet concrete?
ACI 308 shows that properly cured concrete (above 50F and moist) will achieve over 50% of it's strength within 7 days. We're placing a large piece of equipment on a pad and if possible don't want to wait the full 28 days. If the compressive stress due to the equipment is below 50% strength level, can the equipment be placed at 7 days? Is there a chance of settling or sinking within the pad? Is there
RE: Guidance for bearing on wet concrete?
Maine Professional and Structural Engineer. www.fepc.us
TME....bite your tongue!
Figured it couldn't hurt and might provide one more check to ensure the equipment doesn't deform the concrete surface.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Mike McCann, PE, SE (WA)
