Old DC Motor Field Specs wanted
I am lacking field information for the DC motor attached, can anyone assist?
Regards Martin
Regards Martin
RE: Old DC Motor Field Specs wanted
volts and amps?
Gunnar Englund
www.gke.org
Just connect and run! But inspect the innards first. There may be lots of dirt, dead mice and the commutator may need to be overhauled. Check insulation and bearings as well.
Gunnar Englund
www.gke.org
If you disconnet the brushes you can measure field ohms with a ohmeter
Could you send a picture of motor´s terminal box?
