Class X CTs for Normal Protections
Class X CTs are normally used in conjunction with differential or high impedance protections. Is it okay if the same CT is used for other protections e.g. overcurrent, unbalanced load, impedance etc.?
RE: Class X CTs for Normal Protections
no problem with cost and dimension.
