Vacuum pump performance
In our compounding operation , we are beginning to experience vacuum pressure spikes which are effecting product quality . Does anyone know of someone who is good at diagnosing the issues . We have a list of things to review but need a resource to help
RE: Vacuum pump performance
Make a list of things that have changed around the time the problem occurred. For example, were changes made in the formulas? Were equipment changes made?
Did the problem occur in the past? If so, what conditions were known then? Are their vessels/equipment in your plant that don't have vacuum pressure problems? If so, how are they different?
pressure.
Try to capture and analyze the output of the vacuum pump:
Is it air or gas/vapor from the process ?
<nbucska@pcperipherals.com>
If you can't post any detailed process info because of proprietary considerations, I would be willing to sign an NDA and then offer some general diagnostic approaches.
Vacuum is a strange animal and the absolute pressure ranges and chemical components change the behaviors greatly. One technique will not help in all processes.
rushmwr@yahoo.com
