Special Inspections Approved Fabricator Exemptions?
There are possible "approved" fabricator special inspections (IBC 03, CT amd 09) exemptions but other sections, for example steel where certain inspections are required on welds and bolts.
Using the same reference, Connecticut amendment to the IBC notes that exemptions do not apply to "Steel" section of the IBC which is mainly regarding welding and bolting.
Some other states and some interpretations relate the "Steel" section to field work
If the fabricator is exempt due to being "approved" by noted outside QC authorities , is the work inside the shop exempt from the "Steel" and "Wood" inspections which would assumably apply to field and erection work?
RE: Special Inspections Approved Fabricator Exemptions?
