Simulating Double-Acting Cylinders in Arm Assembly
Hi all,
Is there a way to simulate cylinders that move a mechanical arm in a creo assembly. I'd like to animate the arm in use and also possibly get the forces at different points during operation. I think using servo motors will work, but not exactly sure how to set it up correctly. Thanks!
