Slip Ring Connector - Abaqus
I want to model a ribbon inside a sandwich composite using Abaqus. That ribbon should stretch inside the structure and so deform it. For my purpose I've been trying to apply slip ring connector but it didn't work.
Anyone have some guidelines, tutorials or know how they works?
Thank very much in advance for your help
RE: Slip Ring Connector - Abaqus
What exactly does not work with your slipring?
Did you constraine 10th degree of freedom for nodes at the of slipring?
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
Thank you for your interest.
The first think I did was trying to reproduce the example of the above picture. I did the following:
Unfortunately the model ran, but then didn't move.
Dante
I build up model according the sketch. It works fine as long I am using Abaqus/Explicit but it does not work with Abaqus/Standard.
I have no convergence in Abaqus/Standard and I am not able finish calculation with success.
I do not have experience with Abaqus/Standard so I am not able help you with this.
Bartosz
