bearing lubrication oil piping leakage
hi everyone
i need some advice
our turbine gearbox lubrication oil piping leaks oil from connections because of vibration . we decided to replace the pipe with flexible metal hose. do u have any advice or recommendation about such a job?
thanks
i need some advice
thanks
RE: bearing lubrication oil piping leakage
"oil piping leaks oil from connections " is very vague. what leaks and why? Any photos or drawings?
If it's from the joint then secure the joint, if the pipe is vibrating, tie it down,
Is the pipe failing?
Can you stop / reduce the vibrations - If they are that bad then I suspect something is wrong with your turbine or gearbox.
You're looking at the symptom, not the cause.
the vibration of gearbox and turbine is in normal range
