Synchronism check
Synchronism check
I am trying to set up a syn check parameters for a bus transfer system. Not sure which standard to go with. It is 4160V system. No generators.
The parameters I entered for now are:
Voltage difference 104V;
Frequency difference 0.25Hz;
Frequency hysteresis 0.1Hz;
Phase angle 10 degree.
I appreciate it in advance.
RE: Synchronism check
Seems a bit much for a HL/HB.
delta U usually : 5-10%
delta Phi 12-15deg.
7 deg is for generator.
