Timing belt (distance between pulleys)
Hi Users
* I need to lift a plate ~600x700x30mm by using a Timing belt pulley 4nos
* i decided to drive the main pulley with servo motor, and this servo pulley is connected with other pulley through timing belt
hence the 4 pulley have ball screw this will lift the plate parallely
****My question is what is the maximum distance i can keep between each pulley (i will also place a tensioning idler) but need to know in general what can be the distance between each pulleys without idler
Stein
Stein
RE: Timing belt (distance between pulleys)
