42" Field Bending
42" Field Bending
42" Field Bending
Can anyone tell me where I can find some literature on a procedure to bend 42" WT 5/8" in the field. It's along a 33 mile pipeline.
thx
Pete
RE: 42" Field Bending
Ask a construction company or pipie bending supplier like CRC evans
This is a little vague and diffiuclt to understand what you're looking for.
Search pipe bending on U tube and you'll find a few of real life bending.
essentially quite simple, Load the pipe in, clamp one end, lift the other end against the shoe, lower pull the pipe in until the bend is just at the end of the shoe and repeat until you get the angle you want.
Looks quite a thin pipe so you will probably need an internal mandrel, but do a test bend and see what happens.
