Booster Pump with jockey pump
I am working on Power plant for fire protection system. One thing i am confusing regarding booster pump.
The plant is designed with main pump(Duty+Stand-by+Jokey pump) & Booster pump(Duty+stand-by+Jokey pump).
The water source for booster pump is taking from main pump to boost the pressure and supply to stand pipe located on high elevation.
For booster pump, does it need a jockey pump even it is taking water source from main pump with jocey pump?
RE: Booster Pump with jockey pump
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
Travis Mack
MFP Design, LLC
www.mfpdesign.com
Dejan IVANOVIC
Process Engineer, MSChE
