Siemens NX9.0>>Translators>>Dxfdwg
Hello mates,
I have around 150 NX 2D drafting files which need to be translated into *.dxf format. I used "Dxfdwg" option available in translator. But while opening that dxf file using AutoCAD 2015, drawing is not available under "Model" tab. it appears under "Layout" tab in AutoCAD. But if I export individual file using File>>Export>>AutoCAD DXF/DWG, then it converts the file correctly.
Please suggest which settings I need to change.
Nithin
Tool design - NX 9.0
Nithin
RE: Siemens NX9.0>>Translators>>Dxfdwg
It seemed to work better for me,
You will also should get better results when you utilize 2D Exchange
And in NX 9.0 dxf/dwg convertion is moved from 2D Exchange to AutoCAD DXF/DWG option.
Nithin
I've got one additional problem like whenever I translate a drafting file (Using File>>Export>>AutoCAD DXF/DWG) with two or more drawing sheets it export the first sheet every time even though the active sheet may be second or third one.
Your support is highly appreciated.
Nithin
NX 9.0
