RT SOCKETWELDS
RT SOCKETWELDS
RT SOCKETWELDS
Hello:
The RT aplicable to socketweld for verify the GAP, is before or afther weld the joint??
RE: RT SOCKETWELDS
RT is required by customers - not by Codes. Customers require RT, usually on a random basis, after welding. There have been many queries regarding this subject; I suggest that you run a search on the subject.
RE: RT SOCKETWELDS
HI JTE:
IF There is no requirement for a gap after welding, and weld shrinkage can close a gap that was present prior to welding. Then is bether determine if there was a gap prior to welding by radiography, that was a question.
