Metric Drawing format sheet creation
I need to create a new metric drawing format sheet. Everything I have tried, still comes up with dimensions coming in as English and not metric. Any help will be greatly appreciated.
RE: Metric Drawing format sheet creation
dual_dimensioning
dual_dimension_brackets
dual_secondary_units
With proper settings you can get an inch part to display mm dimensions.
If you can't edit the file, then your sys admin has it locked and he/she will have to make the change.
You can try to save a copy of the *.dtl file to your local start-in folder.
Ben Loosli
