Masonry Shear Wall Overturning
I have an 8" solid grouted masonry shear wall and am confused on what load factors to use for overturning moment. The wall is 12' tall and 20' long with a seismic (ASD) load of 10 kips @ 10' and other loads of 200 PLF DL, 300 PLF LL, wall weight of 78 psf and foundation weight. In it's simplest form, OTM will be 10'x10K and RM (20'/2)x All-Dead-loads. What factors do I need use in OTM and RM? Should the ratio be 1.5? Any suggestion and code references will be very much appreciated.
Thank You,
Victor Kesh PE
Thank You,
Victor Kesh PE
RE: Masonry Shear Wall Overturning
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
