Noise Free Dent Removal
Hello Everyone,
I am a senior engineer of production facility which is into converting shipping containers as beautiful living spaces. I have a production facility close to a temple. Since i import off shored containers, there are some dents on those which has to be hammered to rectify them.
However, due to the heavy noise when hammering, people around the facility are a bit worried. These container panels are 2mm thick and has sharp dents so i can't use conventional car dent pullers for this. is there a noise free solution for me? Thanks
RE: Noise Free Dent Removal
I could also envision a custom-made quiet hydraulic dent removal method. Perhaps you could consider relocating the dent removal operation to another location that is less noise sensitive.
Walter Strong
www.linkedin.com
Relocating this operation to another place is not an option because it effects our production process.
Thanks for your suggestions btw
Here is one interesting link:
"Brute Power a division of CHM, Inc. is the manufacturer of Brute Power Container Repair Machine. Brute Power is designed to remove dents in all portions the of a shipping container eliminating the use of heat and reducing the dollying by 75%.
• Brute Power will remove dents in all portions of your container including corner post, end walls, doors and even rack the container back to square. No heating needed.
• If it now takes two men to remove a moderate dent 1 hour this machine is capable of cutting that time in half. Brute Power is capable of repairing totaled containers back to revenue makers.
• 34,000 lbs pushing power @ 5000 psi, silent operation. many options are availible including outside dent removal fixture, hand held corner post tool. Complete training."
Pasted from <http://www.marinetalk.com/articles-marine-companie...;
I have no affiliation with this company or product!
Walt
Azmi
