Inspection of drawing when part is circular
RE: Inspection of drawing when part is circular
Your part appears to be 2 circles joined together with 2 circular holes in the larger circle. It appears that you're taking measurements from the center of the smaller circle. I'm not an expert in mechanical design, but I think the following may be helpful in your design drawing:
1. Have both of the center of the circles defined in the drawing (you currently only show the smaller circle).
2. Provide the radii for both of the circular pieces of the part
3. Align the part so that the centers of the 2 circular pieces are aligned vertically (it's offset in the drawing)
4. Show the distances from the centerline to the point where the 2 circular pieces meet
5. Show the diameter/radius of the holes.
6. Revise the distances to the centers of the holes based upon realignment of the part. I'd also align them based upon the center of the larger circular piece instead of the smaller piece as well.
That's a very odd drawing, since it doesn't even show what the radii of the two larger circles are supposed to be, or how the 6.165 and 5.694 values are to be inspected, since there's no datum, or what diameter the small holes should be, or how to determine orientation or offset. Based on the drawing, there is no constraint on where the two holes could wind up, so long as the 4 dimensions are met, so they could be 1.5 shifted to the left and there would be no basis for rejecting the part, other than that it looks "wrong."
So, the question really must be, "what exactly are you supposed to be inspecting?
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
By the way, you should probably red-flag this thread and re-post in the GD&T forum or Inspection forums:
forum1103: Drafting Standards, GD&T & Tolerance Analysis
forum286: QC, Inspection & Testing engineering
This forum is really more for speculating on the future of engineering
TTFN
1) CMM it ? loft it (use a full size master) ?
2) your dimensions locate things with respect to each other (ie what's the problem) ?
3) you could dim'n the center of the grow-out circle with respect to the centers of the two small holes.
agree that this is probably not the most relevant forum ...
you need to dim'n the center of R3 (the small fillet rad).
there are many ways to inspect the part ... if you can draw a dimension between two physical locations, they have check it. for installations on the outside of the fuselage, we'll dimension from a seat track datum inside the fuselage ... lord knows how they check that !
an easy way would be to make a -ve part (make a hole in a plate to match the outline of your part), "go/no go" gauge.
it'll depend on how many of these you're making, and how critical the dim'ns are.
btw, you should tolerance your dim'ns. maybe there's a standard drawing tolerance ?
The Snowman ain't dimensioned and his body ain't located relative to his head. The bullet holes look well laid out, though. Good shot!
