ETFE Diaphragm valve for abrasive fluid
Halo Valve Experts,
I have to provide diaphragm valve for abrasive fluid, I have chosen soft natural rubber for its material, but it's only ETFE available. is ETFE (ethylene tetrafluoroethylene) suitable to handle abrasive fluid?
thank you,
thank you,
RE: ETFE Diaphragm valve for abrasive fluid
A good producer/supplier has experience and could advice you and come with a proposal for the wetted surface. Ask for a best possible solution for long standing time, not directly if your pre-proposal is the best (that is the second question). Ask at least two vendors.
The best engineer is the one who gets an opinion from more than one expert. (...you are already on the right track...!
A quetch valve or ceramic eccentrick ball-shell v-port valve is possible alternatives, but at higher price, not saying that this is the best choice in your case.
Wear life in this kind of service is tough to predict. There's a lot of trial and error required.
What's the body material? There are lots of diaphragm valves available in all sorts of material combinations.
If your service is hot and abrasive, such that typical elastomers are out of the running, you will be in trouble finding something for the job. Same thing if the service is corrosive or tends to swell typical elastomers such that only Teflon-like materials are a possibility. Then your only elastomer choices would be Viton (FKM) or Kalrez (FFKM) materials. They're not as wear resistant as natural rubber, and cost a great deal more.
