Asme Obround Calculations
In regards to ASME Code for pressure vessels, Does ASME code state or regulate about using calculations for someone else's design as my own?
More specifically, I am under a time crunch and have been going back and forth with our AI and engineering in regards to calculations for an obround flange, and I was thinking it would be OK to use someone else's calculations seeing as it going to be built exactly to the specifications of that design.
Also what would be the correct formula (minimum thickness) to use for the calcs for an obround flange on a nozzle (firetube)for 96 od 75# treater with a repad
RE: Asme Obround Calculations
Section I
Section III
Section VIII Div. 1
Section VIII Div. 2
Section VIII Div. 3
Section X
Section XII
Or some other code?
The obround is 1-3/4 thick 48" long x 27"
You may use calculations performed by others, provided all parties are agreed. However, your organization is ultimately responsible for them.
Mike
