Asme Code Calculations
In regards to asme Code for pressure vessels, Does Asme code state or regulate about using calculations for someone else's design as my own?
More specifically, I am under a time crunch and have been going back and forth with our AI and engineering in regards to calculations for an obround flange, and I was thinking it would be OK to use someone else's calculations seeing as it going to be built exactly to the specifications of that design.
RE: Asme Code Calculations
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
