hydraulic circuit review please
I am re-purposing the mast/cylinder and pump from an old electric forklift as a stationary lift.
I am an instrumentation designer / technician and don't usually get into hydraulic circuits ( just the electrical end ).
Can someone review my design. I would appreciate any advice or comments.
There is actually two designs. They are almost identical. The only difference is that one uses a 3 position 4 port valve and the other a check valve and 2 position 2 port valve.
The 3 position valve give two ways of stopping the lift ( valve and motor ) and better approximates what was there originally ( a manual spool valve that had a switch on it to start the motor).
The 2 position valve and check valve is how most simple ( cheap ) dump trailers are built.
Thanks so much ....... Mike
RE: hydraulic circuit review please
and you only really need a 2 position valve not 3 position.
Yes, the flow valves are pressure compensated priority flow. Because this is a "home project" I was planning on using a "cheap" valve. Northern tool sells Northman ..... FC 51 ... $90
I thought I needed the three position valve ( center closed ) to "hold" the cylinder in position ( if I went with the circuit on the "right" then I only need a two position since I have a check valve to hold in the "up" position ).
I actually want to change the flow while the lift is in motion, this is why the flow valve on both the "up" and "down". I will do this with a mechanical linkage attached to the carriage to "trip" the flow valves.
I am doing this to get rid of the "bump" when starting and stopping the carriage ( it will only have an two positions ... full up and full down).
I realize this is a very odd way of doing things ... but it is considerably cheaper that using a proportional valve with an interface board and a PLC. I actually did this once for a client who had a "large" budget. If I remember, I spent about $3K on parts for the project.
Since this is a lift for myself, the budget is much tighter. The forklift I salved for the project only cost me $850. I figure the entire project will come in at about $3K.
Thanks ..... Mike
The factory engineer just got back to me and suggested ( I think as you did ) that the "down" will not work.
The flow in would be equal to the flow out ( ports EX plus CF ). He suggested plugging the EX ( the excess flow port ) or just putting in a simple ball valve.
Did I miss anything else???
Thanks ..... Mike
Ted
On a forklift forum, it was suggested ( they did not see my circuit as I could no put a picture on my posting ) that I do not start the motor under load.
So, if I am reading both of you guys correctly, I should put a "tee" just after the motor and connect a normally open valve to dump back into the tank.
When I signal my control valve to move, then I will also put power to the "dump" valve.
Does this sound reasonable?
Thanks again .... Mike
Or install a pump unloading valve in the outlet line of the pump. This will automatically dump the pump.
Turn the pump on before operating the system. Turn the pump off when not operating the system.
Ted
If this is true, then the cylinder will drain and come down when in the center position rather than stay up. This is why I chose the closed center option.
I will check ( and maybe you can tell me ) is there an option for some valves to join ports P and T but block A and B ?
Do they make ( and again I will do some homework tonight ), an automatic valve ( I am guessing it would sense differential pressure or flow and close when the system is at rest) or do I do this with a simple solenoid valve?
I truly appreciate all the help!
Mike
A pump unloading valve senses downstream pressure. It opens the pump outlet to tank at a setable pressure. A check valve in the line to the P port of the directional valve maintains the sensed pressure to keep the pump bypassing until either the directional valve is opened or you turn off the pump.
Ted
As I said, I have done a number of jobs but never had the chance to work with hydraulics. It is interesting, I worked for a custom air compressor shop some years ago. We did things very similar ... unloading before starting, unloading and idling large compressors ( and not shutting them off ) when air was not called for.
I do know enough to check with experts before trying to build a project.
I am in VT ... very rural. VT's largest city is only 42,000. Industry is minimal up here. It has been very had to find any "experts" in the are.
I tried a few local forklift and tractor repair shops. They can tell me how to repair items but not how or why systems are designed.
I truly appreciate you help.
I will do a lot more reading this weekend and take another shot at the circuit.
