Catie v5r20 Change part name and update in all closed assemblies
ACarrier (Mechanical)(OP)25 Jun 15 11:50
Catia v5r20.
One part file is open, no other file is open.
Is there a way to change the part geometry and then save this new updated version with a new file name so that all assemblies (unopened assemblies included) replace the old part file with this new one?
Catia v5r20.
RE: Catie v5r20 Change part name and update in all closed assemblies
You need to replace the old file with the new file in the Assembly folder with the same file name as that is pointed by the assembly. you cannot replace a renamed file.
