Motor and vibration structural
Good morning
I hope they can help me with a problem.
We are currently installing a motor of the same specifications that leads to a blower. This engine have performed you tests without the blower in the original structural coupling, we have not had satisfactory results, however we have carried out test with the same engine on a test bench and the results were excellent.
That would be causing me so much structural vibration when I make the test if only this engine differs in weight which is less than the original?
Thanks your help
Thank you
RE: Motor and vibration structural
I do test motor
