design temperature limits for various metals
Hi all,
Can any body guide me on how and where to fine maximum allowable working (Design temperatures) for various metals/materials like carbon steel plates and pipes, SS 300 series plates and pipes and so on.
Also for cast iron materials etc.
does any body have a list for quick reference?
Appreciate your quick response.
RE: design temperature limits for various metals
If you are just talking about application limits then use reference books, manufacturer data sheets, and other such sources.
The advice above is spot-on.
eg: if it's a beam in a walking beam furnace, max service temp = 300C. If it was scale resistance, it'd be higher and dependent upon composition.
Try ASME B16.34
I USE THIS FOR PRESSURE VESSELS
