RedisplayObject() not working
I am trying to use RedisplayObject() method after setting the layers for NX7.5. Although I am able to build my NXOpen C++ application but layers are not getting updated in the view.
Can someone tell me the fix. Or can someone share the source code for RedisplayObject() method.
RE: RedisplayObject() not working
Are you working with a modeling or drafting view? What type of object are you working with, and what did you do to it that you need to call .RedisplayObject?
www.nxjournaling.com
I am working with modeling. Trying to move some features to layers using SETLAYER() method. After using setlayer wanna use RedisplayObject() so that the changes get reflected in the view.
Did you log the feature for update then perform an update?
VB code snippet taken from:
thread561-363348: NXopen - How to move complete DatumCsys to new Layer
CODE
For Each temp As DisplayableObject In DCObj
    temp.Layer = newLayer
    temp.RedisplayObject()
Next
DBuilder.Destroy()
Dim updateMark As Session.UndoMarkId
updateMark = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "update")
Try
    theSession.UpdateManager.LogForUpdate(myFeature)
    theSession.UpdateManager.DoUpdate(updateMark)
Catch ex As Exception
End Try
