USER FATAL MESSAGE 4297
Hi!
I have problem, when I click on results after simulation it gives me the error 'no results are found'. I checked .F06 and I found that fatal message: 'QUAD4 ELEMENT WITH ID = 3446
HAS AN INTERIOR ANGLE POSSIBLY GREATER THAN OR EQUAL 180 DEGREES' What i should do to get results? Please help me
RE: USER FATAL MESSAGE 4297
It is a bad element and it happens time to time, delete it and re-position the nodes to get a better element quality there. Ideally you want all internal angles 90 deg, and a square element in a perfect world.
www.stressebook.com
Stressing Stresslessly!
