Reduced strength of beam due to drilling a hole in a bttm flange
My memory is rusty
Can somebody please give me the steps how to calculate reduced strength od a simply suppoet beam due o drulling a hole in botrom flange
Thank you
If there is an example from any text book that will be helpful
Thank you
RE: Reduced strength of beam due to drilling a hole in a bttm flange
(and in case it's not handy, https://www.aisc.org/WorkArea/showcontent.aspx?id=...)
Thank you is this section on the AISC 9th Edition too?
Is anywhere in AISC 9th Edition stating about holes in flange of beam for bolt and whats negligable and whats not?
Thank you
"It is imperative Cunth doesn't get his hands on those codes."
