ask for drawingviews partname
Hi -
I am right now doing some programming of a NXOpen program (VB) that will cycle through all views in all sheets in a NX drawing part.
My problem is that I am not able to figure out , how to ask for the views "drawing member view" part name.
(I mean - let's say if I manual on a view make > Properties > (tab) General > Information >.
Then - in NX Information window there will be listed a lot of information about the current view..
Some off these informations is:
Drawing Member View Display Settings
What I need is the Part Name from this information.)
My intension with my program is to "change displayed part" and "make workpart" , if a view is a FlatPattern - to the FlatPattern's member PartName.
I have no problems with finding the FlatPattern views - and I can also easily change displayed part, if I was able to ask the FlatPattern view's member as PartName.
Maybe one here on the board can be helpful ,to give me a hint...
Lklo
Lklo
RE: ask for drawingviews partname
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "NXJ journal" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, undoMarkName) For Each temp As Drawings.DraftingView In workPart.DrawingSheets.CurrentDrawingSheet.GetDraftingViews lw.WriteLine("name: " & temp.Name) lw.WriteLine("type: " & temp.GetType.ToString) If TypeOf (temp) Is Drawings.BaseView Then Dim baseViewBuilder1 As Drawings.BaseViewBuilder baseViewBuilder1 = workPart.DraftingViews.CreateBaseViewBuilder(temp) Dim prtView As String = baseViewBuilder1.Style.ViewStyleBase.PartName baseViewBuilder1.Destroy() lw.WriteLine("from part: " & prtView) End If Next lw.Close() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
As usual - you are always good for a competent response.
Your solution can be used in my program.
But in the meantime - I found (in UF_DRAW.h) a userfunction command > > extern UFUNEXPORT int UF_DRAW_get_view_model_view_part in line 2057.
I am almost sure this also can be used as a wrapper function:
ufs.Draw.GetViewModelViewPart(input view as tag , output partname as string)....
But anyway - thank you for your response.
Lklo
