Controlling visibility of Associative Dimensions in NX Modelling
Hi All,
I have searched through the forums but not come across anything that seems remotely like this.
In NX 7.5 Modelling, I am measuring between two points for example but I check Associative under Associative Measure and Checking option.
Also under Results Display, Annotation I select Show Dimension.
In the Part Navigator you can even turn on the associative dimension by highlighting the measurement and selecting Show Dimension on MB3 popup.
The problem is that I have not found method to toggle the dimension off and hiding it hides the complete model...??
Can anyone tell me if there is a simple way to do this?
The only way I found I can do this though it seems a bit extreme to hide a dimension is to use Supress By Expression and toggle it to 0.
Any thoughts or solutions to this puzzle greatly appreciated.
Thanks in advance.
Thanks in advance.
Best Regards
Tetragrammaton :)
RE: Controlling visibility of Associative Dimensions in NX Modelling
www.nxjournaling.com
Thanks, I have no idea why they did not 'seem' to go away previously.
Best Regards
Tetragrammaton :)
