Studio Spline - how to add point NX9 / NX10
Hi all,
I have tried to find answer for my question, if is possible to add point(s) between current in the Studio Spline.
I used to NX 9 and 10.
There isn't option for adding points. I have found some help from thread561-370672: Studio Spline -NX8.5, but doesn't work it.
Do you know some elegantly solution?
Thank you in advance.
Jan
RE: Studio Spline - how to add point NX9 / NX10
I can agree that this isn't that intuitive...
Turn on the "Point on curve" , then you can simply pick a point ON the spline and it will be a new point/ pole. ( in the order where selected) . Then drag this point/pole to whatever position.
See attached image
Tomas
...Unintuitive and with necessary replace the old one for next using, but works.
Thank you for your answer and time
Jan
"and with necessary replace the old one for next using,"
this means ? I don't understand.
Tomas
According your guide I make other spline with using original points plus the new point somewhere among -> I have two splines.
When I have next geometry with link to original spline, I must replace this spline for change of original geometry.
Jan
No need for a second spline. Ignore the other thread and just follow Toost's instructions in this thread.
www.nxjournaling.com
