Inspecting Flat Patterns to Paper Instead of Mylar
Hello all,
I've been in a debate with a tooling inspector and the quality director at my company (gen aviation oem) about inspecting flat pattern parts to Mylar vs paper. For many years here all the drawings were printed on Mylar and it was policy to inspect undimensioned flat patterns to Mylar as opposed to plain paper due to its dimensional stability and robustness. We no longer have the correct style printer to print on Mylar (separate issue.) I made the argument that for a flat pattern part less than 24"x24" the difference in true drawing scale Mylar vs plain paper would be an almost immeasurable difference, and certainly immeasurable with the eye and a steel scale and even calipers. They are worried that the paper is going to grow/shrink in the non climate controlled shop by such an amount so as to cause problems during inspection. I've found thermal expansion values for Mylar but not for plain paper. Does anyone have thermal expansion rates for plain/computer paper? Has anyone dealt with this issue before? I would like to show them numbers that prove that for "x" sized drawing, a temporary paper copy is acceptable to inspect to.
Stephan
Stephan
RE: Inspecting Flat Patterns to Paper Instead of Mylar
I have dealt with the issue of having to re-stretch my vellum drawings every morning due to overnight growth, and would often see a difference of .060" over the length of an E size drawing.
General inspection rules should be applied, and if paper patterns are used the tolerances should be tightened accordingly to allow for shrink/stretch (after that factor has been determined).
While it may be a separate issue, an easy answer is to purchase a suitable plotter.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
if you want to inspect to paper masters, have at it. sure you're bound to accept parts that are out of spec. the problem, if it exists, will become apparent downstream; and that'll mean expensive rework.
why not keep an original master in Al (or whatever) ... ie keep one conforming part as a master ?
B.E.
You are judged not by what you know, but by what you can do.
-Dalai Lama XIV
Suggest inspecting non-dimensioned parts ONLY on mylar** that has benn dimensionally verifyied across the background grid.
Mylar is a streched [strain-hardened] plastic sheet. For this reason, it is biaxially stable. Paper is not biaxially stable.
Strain [due to expansion of the microstructure] from humidity will almost inevitably have un-equal differences along the length of the sheet VS across the sheet.... resulting in non-symetrical dimensional deviations. What a nightmare.
NOTE.
ASME Y14.31 Undimensioned Drawings - Engineering Drawing and Related Documentation Practices has the following statement...
9.3 Reproduction Tolerances
The tolerance for reproductions shall be determined by the accuracy required for manufacturing and inspection
of the item, and by the material used for reproduction. The undimensioned drawing shall indicate directly, or
by reference, the reproduction requirements with a note placed near the title block of each sheet, such as FOR
MANUFACTURING AND INSPECTION PURPOSES, THIS DRAWING SHALL BE REPRODUCED ON STABLE BASE MATERIAL.
** Most plastic [Mylar] drawing media is qualified to L-P-519 PLASTIC SHEET: TRACING, GLAZED AND MATTE FINISH which has very strict dimensional stability requirements.
Regards, Wil Taylor
o Trust - But Verify!
o We believe to be true what we prefer to be true.
o For those who believe, no proof is required; for those who cannot believe, no proof is possible.
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can break them like an artist. [Picasso]
Having said that, in the OP it was noted that the process in question involved a general aviation OEM. As SAITAETGrad noted, manufacture and quality assurance of aircraft components is now entirely process driven. So the inspection technique you are using to validate your flat pattern parts should conform to an existing qualified/approved process, and you should not deviate from this process without approval. Even something as seemingly innocent as changing the material your flat pattern inspection template is printed on (say from mylar to paper) could result in a big non-conformance problem for your company.
Here is a link to a public domain copy of a N-G QA requirements document for sheet metal parts. It includes detailed standards for things like dimensional tolerances of mylar templates.
https://oasis.northgrum.com/contract/miscdocs/QOS-...
Do you have a process specification that would allow you to substitute paper for Mylar ? As I said before this is not a recommended practice.
If you do not, and you did what I said It would be for one piece only , and you would have to get a non conforming part disposition for that.
Do you really want to go that route?
B.E.
It would really benefit you to get these items off vellum. I would suggest having a contractor re-draw them one-by-one as your budget allows and convert them to a dimensioned (albeit loosely dimensioned) drawing. The real issue is... do these need to be inspected at all or was the intent of using the vellum just to give a 'warm fuzzy feeling' that the parts were close to the correct size.
The ANSI Y14 family of specs would be a good reference for learning more about how this should be handled. I would guess your datum structure is not well defined in addition to the issue you are facing. If this is true then the vellum really is a false-positive anyway... but old habits die hard and what was a 'warm fuzzy' may have in time developed into a 'standard practice' at your employer.
The real issue is how long are you going to keep believing the vellum is really helping you - isn't the time and money combined with lack of confidence a risk issue for the company? Similarly if you are using a sub-standard inspection method and getting false-positives why would you resist using a true blueprint with a modern inspection technique like a laser tracker or structured light scanner - which would give you absolute confirmation of compliance?
Best of luck... I have been there before... in today's money-beats-common-sense manufacturing world you need to approach this carefully and get buy in.
The last thing we had to do before releasing the 3D solid model file was check it for accuracy. Boeing had some fairly strict requirements for these solid model files, and it usually required a bit of manual tweaking to get them up to snuff. But I was always very impressed by how accurate the solid models produced from the scanned, hand-drawn mylar masters actually were. The guys that drew the mylar masters were very skilled.
Paper roll plotters also vary significantly in quality and precision. Typically printers used to create mylar prints are made to a standard of precision that's a little higher, in my experience. Your typical HP Deskjet model is not going to be printing things to a precision required for inspection purposes, IMO. Some higher end OCE or special-suited plotter may, but I know the typical 36" roll plotters HP sells at the "budget price" are not that great with pinpoint accuracy of plots.
So even if the material was stable enough... is your plotter even putting the lines in the right place?
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Your point about plotter accuracy has merit. But there is a more fundamental issue to consider. The OP mentioned the paper plots were going to be used as an inspection device to validate sheet metal flat patterns produced by a general aviation OEM. Most aircraft OEMs are now AS9100 certified, which means the tools/gages/fixtures/templates they use for QA purposes must be qualified and calibrated. And it was not clear how AS9100 conforming qualification and calibration could be achieved/maintained with paper inspection templates produced on a plotter.
