Exporting the Assembly into Excel
Hello, I am trying to figure out how to export the Assembly navigator into excel in the same order that it is listed in the Assembly Navigator. I have some code that will export the parts list into excel but it will not do it in the same order as they are listed in the navigator. Can anybody provide some direction?
RE: Exporting the Assembly into Excel
If you right click in a blank area of the Assembly Navigator you can select Export to Spreadsheet
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX7.5, NX9.0, NX10.0(Testing)
Vericut7.3.3
Okay, I was hoping to pull it off by using some VBA in the journal though. It is part of a script I am putting together. However the one thing I can't figure out is how to export via the order of the navigator.
